Measuring curved panel thickness
Hi guys,
I'm having trouble measure the overall thickness of a panel. The panel is slightly contoured in two directions and i would like to know the the overall height of the panel if it was sitting on a ground plane. Kind of like measuring the height of a diner plate when its placed on a table.
RE: Measuring curved panel thickness
Create a plane in the direction of height. Create extremum points both min and max in the direction of the newly created plane.
If you had the CCV module you could apply a stock box to the panel along a given direction.
I attached a bounding box script. I have not used it in a long time as I have created a UDF.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
