which PCB design package to use ?
Hi
I have a choice between Easy Pc and Cadstar Lite,
please can anyone recommend which one has the edge, so to speak
thanks
( I appreciate there is substantial cost difference )
thanks
RE: which PCB design package to use ?
Keith Cress
I have no knowledge of Easy PC or of the current version of CadStar Lite.
Mike Halloran
Pembroke Pines, FL, USA
I will be designing, programmable controller ICs, lots of digital I/O , boards around 300mm square, bridge rectifier, relays, that sort of detail
probably 4 layer at most,
getting mixed vibes on Cadstar, and is does cost. Used it 5 years ago, seemed ok, but that was my first introduction to PCB design,
seeing quite good reports about Easy PC, is around £500.
need to make decision soon, need to crack on with designs
It is easy to use and not very expensive.
-rpoet
For those who are Linux phobic, I suggest trying to run Ubuntu in a Windows based virtual machine. I like Oracle's VirtualBox. Does a great job of running Ubuntu.
