3D Equation Curve
3D Equation Curve
Hello, (Inventor 2013 suite) I am trying to create a variable pitch worm screw,so went about trying the 3D Equation Curve with a view to sweep a cut down the length of a shaft, the 3D curve looks ok, pretty much what i wanted, but when i created a sketch to sweep/cut the end result went haywire, nothing like what i wanted.
Is 3D Equation Curve the right way to achive a variable pitch screw?
Thanks in advance
Thanks in advance
RE: 3D Equation Curve
Did you try specifying the cut profile sketch to stay perpendicular to the shaft axis?
I don't know much about the 3D equation curve tool...I would have tried to make the part with a sequence of linked helices (helix-es?).
http://forums.autodesk.com/t5/Autodesk-Inventor/Va...
Attach the file here.
Its the best I can do at the moment!
Thanks anyway for the input
