Linear Pattern fails when the last instance falls on the edge.
Howdy all,
I'm linear patterning a feature and the pattern falls off the edge of the part on the last instance. When it does the linear pattern fails and only leaves that sliver of the last instance in the model. If I only pattern 6 instances, so all remain on the part, it works like it should. Is there a simple fix so that I can use the Linear pattern for the last instance or should I just create another cut for the last instance of the linear pattern. Using SW 2011 with SP5. Thanks.
-Kirby
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: Linear Pattern fails when the last instance falls on the edge.
Dan
www.eltronresearch.com
Dan's Blog
Your solution seems the most straight forward.
Thanks to both you and Eltron for your suggestion,
-Kirby
Kirby Wilkerson
