ASME CSD-1 Part CE-110 Question
I have a sterilizer and was told that I needed an emergency shutdown switch placed so that the electric boilers that generate the steam for the sterilizers can be shut off quickly. The issue is, the sterilizer that controls the actual boiler runs off of 120 VAC. The boiler itself has heating elements that run off of 208 VAC 3 phase. My question is, which should the emergency shutdown switch shut off, the 120 VAC to the boiler controller or the 208 VAC 3 phase to the boiler heater element?
RE: ASME CSD-1 Part CE-110 Question
Since these sterilizers are Steris, do you guys have anything like that? Or would you recommend having a local electrician come in and take care of this?
