What is the best Cooling system for an open area?
Hello All,
I was asked to design a high end cooling system for an overhang connected to a palace. this Overhang structure is 40meters x 20meters and is open area from 3 sides and meant to provide shade at the building entrance. the temperature can reach 50 degc in the summer and it's a dry weather. One of the suggestions were to install a water mist cooling system.I am asking what is the best system for this application? Budget shouldn't be a limitation.
Thank You
Thank You
RE: What is the best Cooling system for an open area?
For a high end installation you could consider a cooling tower that could be made to look like bell tower or minaret. Spray large drops of water in at the top and let them fall into a basin at the bottom. The falling droplets will create a strong draft of cool air that exits at the bottom that is mist free.
The more conventional solution is to use blowers to draw air through a wet mesh.
TTFN
Water mists are a prime way to transmit legionella.
if you are working on middle east, still evaporative cooling will be pretty good because they have dry climate as far as I konow.
the real problem is when client insists on evaporative cooling in very humid climate, which gives messy results...
quite small plastic pipes are easily integrated within some canopy.
