Range in Thermal Exp Coeff, Non Metals
Hi All,
Could you please help me understand that what does ,"Range,C/F" indicate in "Table C-5 Thermal Expansion Coefficient, Nonmetals", Pg. 247 in ASME B31.3 2008.
Thanks in advance
RE: Range in Thermal Exp Coeff, Non Metals
CTE for most materials changes with temperature. The reported CTE is essentially the average over the given range.
Thanks for the reply.
I have a query that if the reported CTE is average over the range, then which value should be used outside the range.
