Soil pressure on burried vessel
How to calculate the soil pressure on burried vessel if soil density is known, burrial depth is known. Burrial depth is 5 feet, vessel OD is 10 feet, would soil pressure be product of (burrial depth plus OD), Value of g and soil density?
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
RE: Soil pressure on burried vessel
You shall use the maximum g from (water, dry soil, wet soil) to determine the external pressure=static head, just like a submarine. Then you shall calculate the buoyant force (uplift force) to design your anchor system.
External pressure psi = 0.433 x height in ft x density in "g". Use the height to the bottom of the shell.
uplift force Lbs= vessel volume in cubic ft x 62.4, and consider vessel in empty case so not much downward weight to compensate the uplift force.
Some people use strap to hold the vessel down. I still design as a regular drum with saddles and anchor bolts, and sit on two burried concrete piers, simple and easy. Just watch out to double your corrosion allowance.
I have used UL-58 to calculate the buckling pressure.
the value of g I shall take from the soil study report.
Nasir
Welding Engineer
PAKISTAN
