Create Drafting Component for View of Master Model Part
I was scanning through some of the Customer Defaults in NX6, and came across one I didn't understand.
Customer Defaults -> Drafting -> Extras -> Drawing
Under this tab I have 1 option called Drawing Work Flow. The text after the check box reads "Create Drafting Component for View of Master Model Part". The question mark after the text when highlighted states; "This option determines whether or not drafting components will be created when creating a view of the master model part."
Now maybe I have just been looking at this too long, and all chance of logic or understanding has faded (I don't rule it out). But I can't seem to grasp what will happen when I check this box, and I can't find any documentation on it in the help either. If anybody can provide assistance, I would be greatful.
Best Regards,
Best Regards,
John B. Conger
Tool Design
Automotive Interiors
Advanced Engineering Solutions Inc.
http://www.advancedinternational.com/
RE: Create Drafting Component for View of Master Model Part
Perhaps if I describe a typical case where this can be of value.
Let's say have an assembly which comes assembled a certain way but it also has one or more alternative Arrangements, either with the components in different than the default positions or even with alternative parts. And you would like to make a Drawing based on the 'default' version but which also shows some additional views showing one or more of the alternative Arrangements but of course you don't want these alternative parts to mess of the Parts List, such as this example drawing where this assembly could have come with an alternative style handwheel:
Well, even if this Customer Default option was NOT set you can already add an additional view showing a different alternative, like in the example shown above, however, when you add that additional view you have to decide RIGHT THEN AND THERE what Arrangement you want to show. So if you add the view and then change your mind, you're stuck. You'd have to delete the view and start over. However, if the Customer Default option had been set, then this extra view will be created using a separate 'For Reference Only' Drawing Component which, since it's independent, you can now change its Arrangement anytime that you wish.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Best Regards,
John B. Conger
Tool Design
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
why flat-pattern when inserted into an drawing is considered as 'Drawing Component' ?
Flat-pattern is a master model view, like top, front, etc.
For Singsonite :
I suggest to not set this option, because if set you aren't able to macke exoloded views.
Thank you...
Using NX 8 and TC9.1
If an additional Drawing Component is added, will the effect the object count on a parts list?
To Cubalibre00,
Good tip on the option. I had not considered the exploded view. I do wonder if you could still get your exploded view through an arrangement. Not the most ideal approach, but it might work in a pinch.
Thanks for the input.
John B. Conger
Tool Design
if this option is set, you can't use part list, because will be always empty.
Thank you...
