Multiple Shear Lug
Multiple Shear Lug
Hi everybody,
I have a problem with a multiple shear lug (also called "finger type" on Niu's Airframe Stress Analysis and Sizing - page 323).
I have to make a quick check on the lugs, and I cannot find how the shear load is reacted in the lugs in no-failure and failure cases (which lug gets the highest load, ...).
In literature (Niu and Bruhn) I couldn't find anything helpful and I was wondering if there's something available about this kind of joints in order to optimize the design (number of lugs in each side, thickness, ...).
Any advice would be greatly appreciated!
Cheers
Cheers
RE: Multiple Shear Lug
There is a component like the one in the picture (3 lug heads) plus another one with only 2 lug heads. They are connected through a bolt.
How many shear planes are there on the pin? How does the load on the outer two lugs compare with the load an the middle lug in the picture you show? And, how do these loads compare with the loads on the two lug part of the joint? What is the stress in the rectangular bar behind the lug heads. How does the picture you show compare with an eye bar? What is the bearing stress on the pin at various locations?
I’m not going to participate in this thread any longer until you answer the above questions. Awaiting your answers, there is plenty which could be discussed about that kind of a joint.
if you want to go to town on it, i guess the bending stiffness of the bolt would redistribute the load between teh lugs, probably peaking in the center lug. but that'll depend on fits, etc
I ran some analysis and saw that with the particular design solution (3+2 lug heads) is correct to assume that the central lug gets the 60% of the entire load applied in normal operating cases (without failure).
i think if you've got this distribution, then your pin is heading for trouble in bending.
30:40:30 would be more reasonable (given a sensibly designed lug/clevis/pin ... ),
25:50:25 can be rationalised (evenly distributing the load for the two clevis lugs).
if you're thinning down the outer lugs, you'll lose your fail-safe capability (if you want that)
