Air dryer regen purge exhaust
I am putting in an air dryer that uses a blower and an external heater to regenerate the desiccant. I am trying to determine if it is ok to vent the purge exhaust into a building instead of outside. The manufacture does not include instructions on where it is to be vented, but said indoors was ok, and I have seen several dryer packages that have mufflers attached. Any concerns with health/safety of the purged air or carryover (ie. oil vapors from the compressor.)
RE: Air dryer regen purge exhaust
You must know the types of contaminants you expect to release, the concentration buildup inside presumably shop affecting employees and perhaps processes; All of which should be tested and documented in the event OSHA inspectors and perhaps clients wish to know this information.
