Details view boundry
When i made Details view,i its shows boundry in drafting but when take a print it its not visible in print,so every time we make circle in drafting sketch windows,so its time consuming process,any one know better idea about this ,how by befault we got boundry in details view
THANK YOU...
NITIN
UG NX 7.5
RE: Details view boundry
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
see for referance
THANK YOU...
NITIN
UG NX 7.5
THANK YOU...
NITIN
UG NX 7.5
Select the detail view, press MB3, select 'View Dependent Edit...'. When the 'View Dependent Edit' dialog opens, go to the section labeled 'Delete Edits' and select the 3rd icon, titled 'Delete All Edits'. You will be asked if you really want to delete the edits and you will select 'Yes' and you'll be returned to the View Dependent dialog where you will then hit OK and your detailed view should now have a boundary. At least I think that this will resolve your 'problem'.
Anyway, give it a shot and let me know what happens.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
THANK YOU...
NITIN
UG NX 7.5
OK, there are two additional ways in which the permanent circle could have been removed-from-view.
First, go to...
Format -> Layer Settings...
...and toggle all listed layers to be visible.
If that doesn't cause the boundary of your Detail View to show-up, without changing the Layer settings that you just changed, now go to...
Edit -> Show and Hide -> Show All
Now if you still can't see the boundary for your Detailed View, I don't what else to try. I suggest that you contact GTAC, send them your Drawing files and have them look at what might be the problem.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
if i made in new model this problem is solve,but i unable to understand why such problem is happend
THANK YOU...
NITIN
UG NX 7.5
i got a solution of this problem,and came to a point that it is due to layer setting such issue is created....
ok doesen't matter ,finally got solution.
jnikolauk have you got your answer?
Thnks John ...
THANK YOU...
NITIN
UG NX 7.5
