Seismic Weight of Walls
I'm running in to a bit of an issue as I prepare for the SE exam. I'm running into conflicting information about seismic weight.
Example: a one story square building, being analyzed the N-S direction. I would have assigned the dead load of the entire roof, plus one half of the weight of all four walls to the diaphragm. However, several example problems I have seen ignore the weight of the walls parallel to the direction of loading (i.e., the east and west walls); they only factor in the weight of the north and south wall. Is this the proper procedure? If so, is there some reference I'm missing?
RE: Seismic Weight of Walls
If you are designing the main lateral resisting system, then all the walls and mass tributary to each level should be included.
Makes perfect sense.
