Modeling an open channel into a piping system.
I have an area that has seen flooding and I am tying to model the existing conditions. The area is large 100 plus acres and has a number of different culverts, open channels, fields, residential areas and piping systems. I have read the threads along with some videos on line to help. The existing model i have shows flooding during a 2-yr 24 hr event which doesn't happen in real life.
What i have done is the culvert piping under a roadway it treated as a pond with a culvert outlet. The culverts discharge to an open channel for 1000+ feet and goes into a 48"x36" CMP storm drain system. How do I model the open channel. The flooding is concentrated at where the open channel goes int the CMP. I am proposing two detention ponds to slowly release to the CMP. Plese help with the copen channel model.
RE: Modeling an open channel into a piping system.
Of course, if the CMP is the entrance to a storm sewer system, further modeling of the system may be required to account for tailwater effects.
Peter Smart
HydroCAD Software
www.hydrocad.net
What would i choose for the reach? (pipe, Rect/Vee/Trap, Parabolic)? In some areas it has vertical sides and windy in others it is sheet flow with grassy bottom. I have used box pipe with a mannings of 0.03. but the numbers do not seem realistic.
I have HydroCAD 10.00
When you say "the numbers do not seam realistic", exactly what results are you referring to? Remember that the reach routing will only account for normal open-channel flow within the channel. It will not reflect tailwater effects due to the CMP restriction, which would need to be modeled as a pond-and-culvert as noted in my previous reply. In other words, the reach routing is intended to model conveyance without tailwater effects. For details see www.hydrocad.net/reach.htm
Peter Smart
HydroCAD Software
www.hydrocad.net
