Deleting gap (udf)
Deleting gap (udf)
How to delete gap, which is placed as udf (Insert->Symbol->User defined Symbol->GAP).
Thanks.
NX7.0.1.7 64bit
win7 64bit.
Thanks.
NX7.0.1.7 64bit
win7 64bit.
RE: Deleting gap (udf)
The amazing part is how one can drag a symbol on a dimension line, i guess the "place symbol" and "edit component" was written different days...
A small note, a "udf" is a User Defined Feature, not a user defined symbol.
Tomas
Yes, I have quite old drawing with gaps on dimension lines :)
I do it in the same way and if the gap is in the base line you can toggle the arrows off and then on again.
