View creation wizard
as you can see in the image attached, the view creation wizard select the model to import.
This is correct.
In some installations, the view creation wizard select the specification to import.
This is a problem if I create a specification of a sheet metal part where is present the flat-pattern view, that logically is not present in the drop down menu list of the view.
I can select in the wizard the model, but I want understand if is present a setting to set for everyone.
Thank you...
Using NX 8 and TC9.1
RE: View creation wizard
Perhaps, but even if it does happen to pick the 'wrong' file by mistake, you can still change it to the correct part file, can't you? The software has no way of knowing exactly what you want to do, it can only guess, but we give you the option to override this choice anytime that you wish.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you John.
Thank you...
