NERC asks unusual questions
How would anyone answer this question from NERC? "Were there alarms in place to notify of a relay misoperation?"
I would be laughing if they weren't serious.
Are there any manufacturers who's relays provide misoperation alarms?
RE: NERC asks unusual questions
Also, it depends a little on your definition of "misoperation" and knowing NERC, they probably have their own definition. If a relay was supposed to operate but did not, it could conceivably initiate a breaker failure and this would probably be alarmed.
Be VERY careful in thinking that NERC or FERC staff are not informed. They speak a slightly different language perhaps, but they are competent (and they deserve appropriate respect). We usually try to educate ourselves and them so that we can communicate better as a first step.
It still stands that if you ask a question wrong, you may get a wrong answer (Which is a debate we are having, what was the intended question).
Can't NERC hire power system engineers.
Yeah... They light up on the same panel as the fault anticipator.
old field guy
May you grow up to be righteous, may you grow up to be true...
Loss of VT circuit is only good from the VT to the monitor. Dosen't do anything for a loose termation on the relay.
Sort of like the trip circuit monitor.
In the UK the electromechanical distance relays will trip the circuit for a blown fuse, instead of locking up. In some other European countries there's a different approach and the protection will lock up for blown VT fuse, hence relying on the protection ‘to know’ if it's a genuine fault or not. In the UK, having a stiff system they decided to trip regardless, for the same reason they don't lock up the protection for power system swings, deemed unlikely to happen.
So, if you have a circuit trip and distance protection operated at one end only, also VT supervision alarm up (blown fuse), you can work out it was a malop
However our electromechinical panels do have potential lights, and are supose to be checked every month.
In India, they thought that you need a fault to operate a distance protection as well and it ended up in tears:)
