User Defined Object in Welding Symbol Text Area Scaling Problem
I am using NX7.5 and there seems to be some odd behavior of user defined objects while in welding symbols. I have created an encircled number font that works fantastic in text notes and while inserted by themselves. However, every once in awhile when I insert one of these encircled numbers into a welding symbol the scale of it becomes enlarged even though the insert scale is still 1:1. I have attached a photo of the problem. I do not want to use the "Custom Symbol" to solve this problem.
Thanks in advance!
Design Engineer, NX 7.5
