Bend radius for stainless steel
What is the minumum bend radius for stainless steel? The wall thickness is 3mm and the ND is 47mm
I have been told that 1.5 can not be done
RE: Bend radius for stainless steel
1.5 D as a centerline bend would be tough. You may want to use a fitting there.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
Are you intending to bend hot or cold?
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
http://www.iac-intl.com/parts/PB103001r2.pdf
desertfox
If your bender/mandrel set-up manages to maintain the outside wall thickness, then are you going to get localized buckling on the inside of the bend - the stresses of which also reduce the pressure rating? In a nutshell: whatever method you choose to form this bend, what will it do to the pressure rating? Or is the tube not pressurized?
DOL
300 series stainless steel work hardens during forming; therefore the material strength will increase when compared to a straight line of the same material
