Contact elements between volumes
I've created a riveted beam in Ansys using Solid95 elements. There are 2 angles and a plate joined by 2 rivets
To create the contact elements i've used Conta174 et Targe170.
What contact elements should i use for the contact between the contact angle-plate ?
Thank you for your answer
Ruxandra
Student at Ecole des Ponts et Chaussées-Paris
Ruxandra
RE: Contact elements between volumes
I don't really understand how the FKN influence the contact; what value should i choose ?
k is the normal contact stiffness.
A large value of k gives less penetration, but the model can oscillate and you have convergence difficulties.
If the value is too small, there is too much penetration.
You have too try different values. I start with a small value and increase progressively.
It is what I understood, maybe someone will correct
Thank you
One last question.i have a rivet and two plates
Do you know when i define the contact between the plates what kind of contact elements should i choose? I use also Conta174 et Targe170 and i'm talking in consideration the friction coefficient. Is that it, or is there another solution ?
Thank you !
Ruxandra
