structural engineer - need some help
I'm designing a bypass gate for some fan ductwork. During operation, this gate forms the "roof" within the ductwork while air flows through. My question is this - how do I determine the negative pressure (suction) on this gate when air is flowing past it? Here's some info:
- ductwork is feeding a baghouse for a dust collector
- ductwork is roughly 65" square
- the gate is roughly 65" wide x 10' long
- 118,000 CFM
- 3,500 fpm
Any help? It's been awhile since I had to deal with fluid flow......thanks!
- 118,000 CFM
- 3,500 fpm
RE: structural engineer - need some help
>>>These fora should not be used to bypass your own in-depth research on the issues that affect you, nor is it intended to be a substitute for appropriate professional assistance within your field or geographical region.>>>
You may have to consult an Engineer who designs air systems.
Doesn't seem the best approach.
Your use of the phrase "Upon closer inspection" implies you initially had some information to inspect from which you eventually gained the information you needed. There is no indication from your first post that you obtained additional drawings. Hence willard3's comment.
Frankly, I assumed that you looked closer at the drawings you already had examined and found what you needed. Happens to me all the time. :)
No worries though.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
