Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Over the past year I have found your site to be EXCELLENT. Never have I been able to find so many answers to such vast problems and it is an excellent service..."
Geography
lightecho (Mechanical)
28 Aug 12 15:16
As AHJs, when do you draw the line for tenant improvements and require engineered calcs?
D
A thing moderately good is not so good as it ought to be
Thomas Paine
www.ykfireprevention.ca
28 Aug 12 15:19
Apologies for the lack of clarity. When having to modify a sprinkler system and add sprinkler heads to accommodate TIs, when do you require engineering?
D
Thomas Paine
NewtonFP (Automotive)
28 Aug 12 15:57
I am not an AHJ. However some AHJ's locally require calculations anywhere between a minimum of 5 to 20 sprinklers affected by changes in the system.
It is worth noting that some bid shell spaces light hazard to get the job and when the tenants move in the system needs demolished and replaced with a system capable of accommodating the new hazard.
cdafd (Specifier/Regulator)
28 Aug 12 17:35
hate to say rarely, but where I am at now it is mainly just moving heads, and adding a couple.
Now if it was a storage situation, or change of use for the space, that would change the game plan.
stookeyfpe (Specifier/Regulator)
29 Aug 12 16:29
I always require calculations if the designer uses Special Sprinklers, as defined in NFPA 13. I had a TI last month that was using EC sidewalls for an OH Group 1 design. The required starting pressure was 55 PSIG, which ended up increasing some branch line diameters. This is why the jurisdiction's I support have a requirement that for <20 sprinkler TIs, calculations are not required for K= 5.6 sprinklers and existing pipe schedule systems. Anything else generally requires calculations.
Close Box
Join Eng-Tips® Today!
Join Us             Close
