Fitting things into other things?
Hey, SolidWorks users, I was wondering: Is there a way I can use SolidWorks to build a container in CAD, and then, with boundary conditions, see whether an object fits inside that container without sticking through the sides? I've been doing some searches, but I have come up empty, since I do not know what category this would fall under.
RE: Fitting things into other things?
Have you tried making an assembly? insert it into the container, see if it fits.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
One method would be to create a multi-body part using the Insert > Part function and then using the Combine tool with the Common option to show any interfering portions.
So, there's looking at it visually, but, suppose I had multiple instances of smaller objects that I wish to fit inside the bigger object? This is a 3-D "bin packing" problem, in a way. I'd love for the program to determine an optimal position. So, to ctopher, that works if I was eyeing it, but I'm imperfect, and might miss a more optimal solution.
Combine + common actually sounds rather interesting, and I might pursue that. I was hoping for a program to determine a better fit, but I suppose I will just have to eye it.
What shapes are involved? Rectangles or curvy-swoopy?
The shapes involved, initially, can be described as polyhedrons with very low polygon count. Later on, the "bounding box" might become an annulus of some sort.
I am not aware of a means to optimize component placement, but you can see if parts "fit" by checking for interference. In the assembly go to Tools ==> Interference Detection.
- - -Updraft
Sounds like you need to optimize the nesting, as it were. Something you could try would be a physical simulation where the parts would fall into the bin and you could do a count. Where it is a physical simulation, your results should vary a bit each time as to the amount of parts that fit in the bin prior to them overflowing. Then, just get the average.
Granted, this may be a PITA to set up, but it'd be a fun way to find out how many fit.
Jeff Mirisola
My Blog
No.
-Dustin
Professional Engineer
Pretty good with SolidWorks
