Remove Ordinate Leader Lines
Hi All,
Can anyone tell me how to remove these annoying ordinate leader lines? I feel like I've dug through all the menu options to no avail.
In case my upload doesn't work, I have leader lines going from the ordinate to the dimension (perpendicular), which are really cluttering my drawing. Any guidance would be much appreciated.
RE: Remove Ordinate Leader Lines
Activate the ordinate dimension in case, Pick the dimension style button in the toolbar, see attached image.
Tomas
I really on't think the default should be "on".
I haven't worked with ordinate dimensions yet in NX7.5, so I am glad to see this before I did.
My mistake was with object selection. I had been trying to edit the style(Show Dimension Line checkbox) of the individual dinmensional callouts rather than editing the style of the ordinate itself. Makes sense. Thanks again.
The "show dimension line"=on is the ISO-appearance.
What is your customer default setting : Drafting - General - Standard - Drafting standard = ?
- I guess that is can be avoided by setting this to ASME ?
Tomas
I've already changed the drawings in question, but I will use ASME(Shipped) for my drafting standard in the next drawing and see what happens.
