Converting User Defined Constraint to Mechanism connection
Problem that is driving me crazy.
I have a model that I would like to do work in mechanism with, but I cannot figure out how to convert the assembly constraints into mechanism connections, the option is grayed out and I am stuck with a "User-defined" connection. I have tried deleting all previous constraints to no evail, please help if you can.
I attached a snapshot of the dashboard as a previous thread explained to uncheck the allow assumptions. Unfortunately, this does nothing for me.
thread554-273602: Convert a Constraint to a Connection in Mechanism?
