Problem with imported hydrographs
I have a large, complicated model, that I'm running 6 storms through, and then I'm exporting the hydrographs using the Automatic Export Settings feature. Then I'm importing the downstream most node (node 43 in this case) into a smaller model. I only really need to heavily monkey with the smaller model - all the stuff in the larger model should remain fixed. When I try to close the larger model, it runs through the 1, 2, 5, and 10 year storms, and somewhere along the line, I get an error that looks like this:
...but each time I exit it, I get the same error on a different subcatchment. Sometimes it hangs on the 25 year storm, sometimes the 50. There appears to be no rhyme or reason for which storm or node it hangs on. When I go to my other file, the hydrographs import properly for whichever storms it successfully ran through before hanging and giving me the above error message, but the remaining storms are missing, giving me an error that looks like this:
Ideas?
Quote:
HydroCAD 10.00-3 s/n 06623
Automatic export failed:
Cannot open file C:\Users\bj\Documents\My Dropbox\CCC\Projects\10.001_SCE\12014_Avalon\HydroCAD\12014-north-predev~Subcat 13.hce
Error 650: Link 2L External hydrograph not found
Event: 25
Ideas?
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
RE: Problem with imported hydrographs
Make sure you're exporting "Unrouted Outflows" and not "All Outflows". The latter option will generate many unneeded files. The former option will export only the essential nodes.
Peter Smart
HydroCAD Software
www.hydrocad.net
Thanks for the tip on the 'unrouted' thing - I was doing that 'wrong.'
Peter Smart
HydroCAD Software
www.hydrocad.net
