COMMON DATUM
COMMON DATUM
COMMON DATUM
My question concerns the "COMMON DATUM".
It is possible to create a "DATUM" bottom a control frame who calling 2 commons datums whose himself ?
See my picture to example.
RE: COMMON DATUM
Where to start? First, under each FCF, the note "OVER DATUM A" and "OVER DATUM B" is incorrect and unnecessary. Second, perhaps shift the nuts further along the tube segments so that it isn't in the zones establishing Datum Feature A and Datum Feature B. At the same time, you need to show an offset chain line representing the segments for Datum Feature A and Datum Feature B. Third, it is maybe confusing to put the Datum Identifyer symbol on the FCF in THIS instance where the Datum Feature (A and B individually) is controlled back to the Datum established by Multiple Datum Features. I would put the Datum-A and Datum-B identifiers on the chain lines indicated in the second point.
Note, you may well get a lot of people opposed to the idea of controlling a Datum Feature back to a compound datum, but it is legal.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
