Titanium gasket seating data
For a customer I have to recalculate flanges for a heat exchanger. I need the minimum and maximum allowable gasket seating stresses of a Titanium Gr.1 (ASTM B265 Gr.1) Ø1199xØ1145x6 mm (47.2"x45"x0,25") solid flat gasket.
Is there any literature where I could possibly find these data, or is there anybody how knows this?
Kind regards,
Kelly
Kind regards,
Kelly
RE: Titanium gasket seating data
That is our problem right now. It is not a problem if we have to change the calculation, but we must clarify where gasket parameters come from.
Kind regards,
Kelly
Now, are you talking about the "y" value used in Appendix 2 design, or are you talking about applied assembly stress?
Mike
I have had contact with a gasket manufacturer and a heat-exchanger manufacturer which uses solid titanium gaskets. I have not had the time to figure out wether the formula's they provided can be of use for me. I have yet to study them.
Kelly
