Selection of coating system to prevent CUI
Has it been proven that carbon steel surface needs coating system to prevent CUI. I understand there are various factors that control the CUI, coating system alone cannot prevent. The new API RP 583 does not address selection of coating system. It's easy to say that one need to select a right coating system based on the full understanding of CUI, but, my basic question is what is the percent of success on carbon steel surface coating aginst CUI. This is just to alleviate my reservation against coating to protect CUI on carbon steel.
RE: Selection of coating system to prevent CUI
Consult NACE SP0198 and API RP 581, Part 2, Section 17.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Is there a reason for the bold italics? Now that I know what CUI means, I have no opinion to offer the OP.
Steve Jones
Steve Jones
If we all did that, you would lose the advantage. It just looks rude to me...shouting.
You can show your appreciation to other posters in two ways. You can click at the bottom left of the post, where it says that you thank the poster. You can also use the "Emotions" button to the left of the "Submit Post" bar.
Steve Jones
The decision to paint, or not, should be based on the corrosion risk assessment. You are building a case for low probability of CUI occurrence. Now consider the consequences of a leak or rupture if it occurs, followed by how much inspection would be incurred in trying to find the CUI before a leak or rupture. Of course, painting does not provide immunity, but it can help with the probability. So, as you can see, it is very difficult to advise whether to paint or not because we can't perform the risk assessment.
Steve Jones
http://www.paintsquare.com/webinars/?fuseaction=ar...
We seem to forget the “I” in CUI and underestimate the influence of proper insulation design.
The NACE emphasizes on coatings and clearly favours TCA for heavy duty environments. My issue with the NACE SP0198 is that it doesn’t focus enough on the influence of insulation. We all know that wet saturated insulation creates the unwanted electrolyte, so my point is to engineer a fit-for-purpose insulations systems that allows water/moisture to drain or evaporate. There are several well documented standards which describe the use of drainplugs, aircavities, non-contact insulation or the use wicking materials. Any coating whether it’s zinc, silicate coating or even TSA are subject to the QA/QC regime and the quality level of application. Also the equipment design e.g. chamfer all sharp edges, drain holes in vacuum rings, protrusions etc. have a big influence whether a coating will meet it’s expected lifecycle. The EFC 55 CUI guideline, which is currently under review for an update, has a multi disciplinary approach which also covers a RBI method. Lets remember that CUI like any other unwantend corrosion is a organisation issue which is primary an asset-owners responsibility.
Johan
www.linkedin.com/in/johansentjens
