Cooling Tower Cell Arrangement Design
Dear All,
I am currently involved in a mega petrochemical complex project. The overall cooling water consumption is more than 130,000 m3/h (10& margin) and the initial design is to split to users into 2 main clusters, so end up with 2 block/cooling tower in two different locations within the complex.
There are 18 and 16 cells respectively for each cooling tower (one basin each) with 4000 m3/h per cell.
The issue is we are at the bottleneck on the cell arrangement. There are two options:
a) 9 x 2 (rows) and 8 x 2 (rows)
b) 6 x 3 (rows) and 5 x 3 (rows)
The above 2 options are being discussed between ourselves (project owner) and contractor. Contractor is preferring option 2 with the reason of easy maintenance and piping/nozzle layout
However, project owner side is in the opinion that by having three rows will not have maintenance issue.
By having 2 rows of cell arrangement(option a), the overall unit length will be too long compare to option b.
Appreciate your feedback. Thank you.
RE: Cooling Tower Cell Arrangement Design
Also, just wondering the option B will have the STARVING TOWER FOR AIR scenario since there is a row of cell in the middle of the entire unit apart from what you described earlier.
In terms of maintenance and piping/nozzle layout consideration, what is your opinion on this aspect for both options?
Thanks in advance.
For the two parallel units there could be a common header for CW return between the 2 units, with pumps located on the outboard side.
For the 3 units in parallel, I think (if tower lenghts are E-W) you would have the headers all on the N or S side of each row, with pumps on the opposite sides.
Here is one that was installed 1056 ft long (100,750 m3/h):
http://www.geapowercooling.com/opencms/opencms/gpc...
I suggest you involve the aid of some good piping / layout designers / engineers to get a better handle on the proposed installation.
One thing for sure you need to have the cooling tower vendor tell you the minimum spacing between rows.
http://www.classikcoolingtowers.com/modular-coolin...
Note that the risers are both fed from the middle "aisle".
Good luck!
Anyhow, it seems like option B with all cells grouped together would probably need further enhancement.
Looking on the web I only see a few 2 row back / to back installations and no 3 row back to back to back units.
I suppose that is just a way too keep the fan blades from getting too long in radius. So maybe my first statement is incorrect.
This is something I would put heavily in the vendor's area of expertise.
2) no. of cells can be optimized by using more blades per fan and hence the total operation and maintenance cost can be saved.
Regardless, thanks you guys for all the valuable inputs...Cheers!
http://www.sciencephoto.com/media/342223/enlarge
I would want to choose a supplier / field erection contractor that has demonstrated prior experience in similar projects.
This may put some of the smaller suppliers out of the picture.
Again, I think the decision should be governed by what the tower supplier recommends.
