Why is the lower thickness limited for Impact Tested Welding Procedures?
Hi! Time and again I stuck to the question that: Why is the lower thickness limited for Impact Tested Welding Procedures?. Where as Metallurgically, increasing the thickness usually increases the chances of retained austenite/martensite, thereby decreasing fracture toughness/impact strength.
Thanks in advance.
Salmet
Thanks in advance.
Salmet
RE: Why is the lower thickness limited for Impact Tested Welding Procedures?
Primary cooling during welding is through conduction (metals have high heat conductivity) and not through convection. The greater the heat sink (mass/volume) the faster the cooling rate.
