Simplorer Help
Simplorer Help
Hi everyone.
I've modeled a three-fase induction motor in Maxwell 2D 14.0 and I'm trying to import it in Simplorer to simulate some kinds of starts with reduced voltage.
To begin I imported using the command Subcirtuit > Maxwell Component > Add Transient Cosimulation, and chose the Maxwell file with the modeled motor.
Well, the component appears with two Pins that, I think, gives the rotor velocity: Motion_setup_Out and OMEGA;
In the first one I can conect the VM_ROT which is a Angular Velocity Meter, but the program put between them a block called ROTB_ROT1 that I don't know what it is.
But the velocity shows zero with simulation, even connected correctly the three voltage sources to the windings.
The second one, I even found a block that I can connect to it.
I've already looked for tutorial, manual, exemples in Google, but I didn't found anything that could help me
This project is my Final Project for course graduating. If anybody could help me I would be thankful.
I attached the Maxwell 2D (14.0) model and the Simplorer file if necessary.
http://files.engineering.com/getfile.aspx?folder=2...
http://files.engineering.com/getfile.aspx?folder=7...
Fábio
Fábio
