Humidity of Electrode Storage Room?
What is recommended RH (Relative Humidity) of the electrode storage room?
We are recording 60 to 70% RH with ambient temperature 35C to 40C.
We have some old written procedure that requires RH should be less than 40%. It further says if RH is over 40%, then do dehumidification unless RH is lowered down to 40%.
Any advice please?
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
RE: Humidity of Electrode Storage Room?
Totally wrong forum- welding forum is better.
Maximum 50% relative humidity at 35 to 40 deg C room temperature based on several audits I have attended with boiler manufacturers. My best advice is to check with the welding consumable suppliers.
What counts - if the opened SMAW (stick) rods are in an oven at the proper temperature (well over 100 C!!) and the unopened SMAW rods are in their original sealed containers - is the temperature inside the ovens.
