Weirs Coefficients
Weirs Coefficients
I am modeling a flooding situation where a local low point overtops and earthen berm. I have modeled the the low point as a pond and the existing berm (approx 40 feet long with a 6" high flow) as a custom weir with the default coefficient of 2.62. I was requested to provide a coefficient which considers the light brush and vegetation along the top of the berm. How would I best consider the "roughness" of weir material (i.e. vegetated).
RE: Weirs Coefficients
http://pubs.usgs.gov/wsp/1617a/report.pdf
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
Rectangular Weir: C = 2/3 sqrt(2g) Cd (e.g. 3.26)
V-notch or Custom Weir: Cv = 8/15 sqrt(2g) Cd (e.g. 2.61)
Where g is the gravitational constant, and Cd is the unit-less discharge coefficient, which is typically 0.61, giving the typical C values shown above.
Note that the v-notch weir coefficient (which is also used for a custom weir in HydroCAD) is 80% of the rectangular weir coefficient. So you need to be careful when using a custom coefficient.
Peter Smart
HydroCAD Software
www.hydrocad.net
Peter Smart
HydroCAD Software
www.hydrocad.net
