CPU Thottleing (NX 6)
is there a setting that will keep the program from using more than 25%? it will take forever to do anything and when I open the task manager its maxed out the CPU at ONLY 25%...
Cj Silver
Senior Tooling Engineer
GKN Aerospace
If a glass is half full is it...
a.) Half full
b.) half empty
c.) twice as big as it needs to be
D.) created by an supervisior
RE: CPU Thottleing (NX 6)
www.nxjournaling.com
Mircosoft, in the their infinity wisdom, has decided that for multi-core configurations, that the 'Performance' Panel of the Task Manager, with its 'CPU Usage' column, will show the status of THAT core which is currently being used most fully, but that it reports this usage by as a percentage of what IT contributes to the POTENTIAL of all the cores. Therefore, for a quad-core configuration, the best that you will ever see 'reported' in the 'CPU Usage' column will be 25%, for a dual-core this maximum will be 50%, and so on.
Therefore, if you're seeing a 'CPU Usage' of 25%, you're already maxed-out.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
