Can't return to Modeling application once I enter Drafting
I am using NX 7.5. I can start a new model with no problems but when I switch to the Drafting application I am stuck. When I click on "Start" in UG, the only thing that shows up is Gateway so I can't get back to the actual model. I don't really know if it is a computer problem or if it is a setting in UG that I am missing. I am using the same license as most other people in the company are but I am the only one having this issue. Any ideas? Thanks.
RE: Can't return to Modeling application once I enter Drafting
www.nxjournaling.com
