Split balloon with attributes and callout
Hi
I'm using NX6. In drafting I'm trying to use ID symbol which is a divided circle. How can set top half as call out (system generated in part list) and bottom half as an attribute?
RE: Split balloon with attributes and callout
You can do the Attribute assignment with NX 6.0, but you can't associate the automatic Parts List 'Callout' letter/number until NX 8.0.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
You cannot have the item number automatically put in, but you can do it manually.
You will have to create it in the annotation editor, and cut it from there and paste it into the ID symbol.
Here is a thread that eplains that: http://www.eng-tips.com/viewthread.cfm?qid=218438
thanks! but in my case association with the part list is the key. otherwise every time the part list gets updated the manual text will be wiped off.
Well, you could always start lobbying to get upgraded to NX 8.0...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
When your parts list gets updated the manual item number attribute that I explain will update too.
It will not be wiped off.
Give it a try on a small assembly.
