Best pump for closed valve conditions?
I am designing a control system where there will often be a closed valve downstream of a pump. What type of pump will work best under this condition for long periods of time? I know positive displacement pumps are out of the question, but I'm not sure centrifugal would be the best either.
I'm not sure if it will change anything, but the pipe is only 1/2".
Thanks in advance.
Thanks in advance.
RE: Best pump for closed valve conditions?
Or use a fixed displacement pump with an unloading valve which unloads the pump when the valve is closed.
What is the application? Fluid?
Ted
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
Yes, HydTools, it is for fluids. I like the fixed displacement pump idea. Thanks.
One would think that any pump would overheat during a situation where the pump is deadheading for a prolonged time period.
In some cases a deliberate flushing flow is fed into the pump case, taken either from the pump's own outlet (I don't particularly like that) or from a separate cooling circuit (much better). Some pumps have no separate case drain port and leak instead into their own suction port - this type cannot stand running for long periods in a deadhead condition because they will overheat (usually a matter of minutes).
If there is enough "capacitance" in the downstream circuit then you can use a fixed displacement pump and an unloading valve. The valve can sense the downstream pressure and divert the pump outlet flow back to tank/bypass at low pressure. A check valve prevents the downstream circuit from de-pressurising when the unloading valve does its thing. Insufficienct "capacitance" will mean that the downstream circuit depressurises too quickly when the pump goes off load and the unloading valve switches it back in again too quickly (hunting).
If the time periods are long enough then the unloading valve can be replaced with a pressure switch, a timer and the on/off control. Sensing the system pressure being up at relief valve setting and remaining there for a certain period of time will cause the pump to turn off. When the pressure drops the pump can start again. You don't want the motor to suffer from too many starts per hour so you can only do this trick for systems with infrequent cycling.
An alternative scheme could employ a very small pump as well as the larger (unloadable/turn-off-able) pump. The small pump would keep topping up the downstream circuit and just blow the excess flow across a relief valve. Yes there is energy wastage and heat generation but this might be within tolerable limits.
DOL
http://www.hydro-gear.com/Main/Products/PistonPump...
