Selected Cg (Flow Coefficiant) Maximum and Minimum
Hello Everyone,
Im currently working on sizing some control valves. They are anti-surge valves. Im trying get my head around the flow coefficient and what it exactly means. When valves are being sized you are normally given values of CgMin CgMax. I also see a Selected Cg value.
What do these three coefficients tell me?
Thanks in Advanced
RE: Selected Cg (Flow Coefficiant) Maximum and Minimum
Cg is a valve sizing parameter developed by Fisher (Emerson now). It's related to Cv by the equation Cg/C1 = Cv. For a lot of globe style valves, C1 is around 30.
The minimum and maximum Cg are conditions you specify that indicate:
The minimum valve flowing requirement of the application
The maximum valve flowing requirement of the application
The selected Cg is the Cg of the valve you have selected.
Anti-surge valves are tricky. They are usually oversized by factors of 1.5 to 2. You may want to look on the internet for guidence.
