Aligning section views
Does anyone have problems creating alignments for section views, e.g. aligning section A-A with D-D?
You'll need to delete the alignment with the sectioned part before you can create a new alignment. For some reason I can only delete this alignment if I pull out the section to the right of the part. It doesn't matter what the direction of the section line is.
Weird..
Weird..
RE: Aligning section views
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
