ductwork made easy in solidworks
Hi everyone,
I'm pretty new to the forums and solidworks and was wondering if i could get a little help.
Basically what I'm trying to do is make ductwork in solidworks with the right seams/connectors etc. which is easy enough, but time consuming when I am handed 20 fittings in the morning and am expected to have them cut out with the plasma by lunchtime.
I have most of the parameters set in the design tables (length, width, radius) but I need the height to be adjustable in the table too. I used a seperate plane to put a sketch on the top, and then used the lofted bend feature to connect the top and bottom.
TLDR, I was wondering if there was a way to adjust the height of a custom plane in a design table. I attached one of the said files for reference.
also I would like to be able to adjust base flange/tab height from a design table too if anyone knows how to do that, I'll attach my elbow file as well so you can see what I mean.
Thanks guys!
Thanks guys!
RE: ductwork made easy in solidworks
Cole M
CSWP, CSWST, CSWI, CPDM
Certified DriveWorks AE
That would work great, only all it lets me do is change the file name and not any of the dimensions/features etc.
http://help.solidworks.com/2012/English/SolidWorks...
Check out this link http://www.driveworksxpress.com/index.php/training It has tutorials that will show you how to properly set up a DriveWorksXpress project so you can control dimensions and features. Also since DriveWorksXpress is part of the standard SolidWorks product your VAR should be able to help you out as well.
Cole M
Michael McMillan
http://cadtechie.blogspot.com/
Michael McMillan
