2205/6% MOLY (75/25 SPLIT
Does anyone know the SA spec No. or the UNS for material that would be applicable when 2205/6% MOLY (75/25 SPLIT) material is called for. I don't know where to find details or a manufacturer of such a product. Any basic info would be very helpful
RE: 2205/6% MOLY (75/25 SPLIT
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
You will need to join these two alloys, however. The filler metal will be the one used for the higher alloy base metal, in this case it is non-matching = Inconel. You will also need to respect the heat input requirements of the 2205 duplex so as not to damage its corrosion resistance and fracture toughness.
Don't give this work to a back-alley carbon steel shop.
