Shortcuts
Shortcuts
Somebody know if there is a shortcut to open a file & print, in NX7.5?
Angel Zapata
Angel Zapata
RE: Shortcuts
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Shortcuts
RE: Shortcuts
Chances are that your computer is up for retirement, Vista ( which is retired by Microsoft) is a known performance killer, both on cpu and graphics.
How old is it ?
RE: Shortcuts
RE: Shortcuts
In case you run a 32 bit OS you can at the max utilize 3 GB, after setting a switch in Windows.
Without this switch you are limited to 2Gb. ( No matter of how much your computer has installed.)
In case you run 64bit version of Vista and has the 64 bit version of NX installed, you should have no less than 8 Gb, and yes then you should see performance increase. What happens is that when windows is closing in on the memory limit for the RAM, it starts to swap out from RAM to HDD, then the performance drops radically. If you have "lots of RAM" ( I have 16 GB in my laptop) this swapping will "never" happen.
Also the graphics adapter is , if "the engine is too small" reduce speed radically,
it's like in a car, if your engine outputs 15 Hp, it will be very-very slow but one will not see any radical difference between 400 and 500 Hp.
Tomas
