RH Albert Pre-Eng Steel Buildings
Sign on PEMB at ridge says “Steel R.H. Albert” on the left side and “BLDGS. & Co. LTD.” on the right side. The building is about 40 years old and was supplied from/to Western or Northern Canada.
Does anyone have any information about this fabricator?
Dik
Dik
RE: RH Albert Pre-Eng Steel Buildings
When you deal with existing PEMBs, you're pretty much on your own, sailing into uncharted waters.
Dik
dik...sorry, but can't help. I have run into similar in the past couple of years with defunct PEMB fabricators. Check corporate ownership streams if available as many of these were absorbed by others over the years. I have one from the 60's I'm currently chasing.
Dik
In addition, most of the PEMB mfgs suggest that their buildings are good for 20 years or so. If it is 40 years old ---- all I can say - "GOOD LUCK"
BA
Dik
