command line
command line
Is there a command line in Femap?
i need to control the Femap using Fortran and then i need a file that contains these commands.
RE: command line
No, FEMAP is not command driven, but "menu" driven.
You can connect with FEMAP using the API -- Application Program Interface.
The FEMAP API is an OLE/COM-based programming interface to FEMAP. It contains hundreds of functions that can be called from Visual Basic, VBA (Excel, Word, Access, ... ), C, or C++. The FEMAP API Reference documents the objects and functions that are available in the FEMAP API.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
