Stop CATIA from creating new product on startup
Every time I start CATIA it opens a new product document. Is there any way to stop this? I want CATIA to do nothing on open.
Nick
Light structural commercial aircraft parts
PCDMIS 4.3 CAD++, CATIA V5 R20, NX6
APM Consortium Inc.
Cambridge Ontario, Canada
RE: Stop CATIA from creating new product on startup
Add the following variables to your Environment System variables\
Blank Catia
CatNoStartDocument = 1
No spash screen on startup
CNextSplashScreen = no
needed when you are using R22 and LUM licensing.
DSLICENSING = Legacy
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Awesome. Thank you(s).
Nick
APM Consortium Inc.
The simplest way to stop this is simply inserting
CATNoStartDocument=yes
into your CATSettings. You don't need to create any environment variable or anything else.
Is that not the exact thing as the original answer?
Nick
APM Consortium Inc.
There are 3 locations to add the variables.
System Properties --> Environment Variables --> User Variables --- only good for that user and any version Catia
--> System Vars --- good for all users and any version of Catia
Catia environment by default C:\Documents and Settings\All Users\Application Data\DassaultSystemes\CATEnv\CATIA.V5R20.B20.txt (name and location may vary)
Any setting in the Catia environment file will supersede the System properties.
I prefer the System var location, IT sets the variables once.
Derek
Win XP64
Dell T7400 16GB Ram
