line width and body color; vb script
Hello. I guess I will basically asking this to Ferdo, because I'm sure he'll be the first to reply.
I have been to many resources about VBA scripting. Everywhere I go I learn the same thing; about data types and loops. I totally understand this kind of stuff in VBA, but I have no idea where to START with CATIA. I have yet to find a resource that describes what the wording looks like to select say, a body's color property, and how to change it. Or how to open the properties dialog while a part is selected and change a property.
Without the record macro option, there is no way to learn this stuff.
I will ask for a specific example of what I expect to be a dead simple script.
With a CATPart file open with a single body. I wish to select the body with the mouse. Then I wish to hit a button that will run a script (I know how to assign a macro to a button). I want that script to change the color of the body to a light grey, and then change the line width to the thinnest available line width.
I feel like if I SEE this script, I will be able to start figuring out how to make my own. My scripts will likely all be extremely simple like this one, just changing properties in bulk.
That's it.
I would be unendingly greatful for help with this one. Again, I'm asking someone to write this for me, so I can see it and learn some basic CATIA language.
Nick
That's it.
Nick
Light structural commercial aircraft parts
PCDMIS 4.3 CAD++, CATIA V5 R20, NX6
APM Consortium Inc.
Cambridge Ontario, Canada
RE: line width and body color; vb script
Bellow CATScript will give you some ideas.
' Purpose: 'The goal of this macro is to demonstrate the change of visualization (properties of objects)
' Usage: 1 - A CATProduct must be active, few components in spec tree selected by user
' 2 - Run macro
' Author: ferdo (Disclaimer: You use this code at your own risk)
Language="VBSCRIPT"
Sub CATMain()
Dim Selection0 As Selection
Set Selection0 = CATIA.ActiveDocument.Selection
Dim Obj2 As VisProperties
Set Obj2 = Selection0.VisProperties
sLF = Chr(10)
'input data for RGB code (try for example RGB code=0,0,255 ; r=0 , g=0 , b=255 , objects will be colored in blue )
r = InputBox ("Write red code color here, for example 0 from RGB code 0,0,255" & chr(13) , "RED", r)
g = InputBox ("Write green color here, for example 0 from RGB code 0,0,255"& chr(13) , "GREEN", g)
b= InputBox ("Write blue color here, for example 255 from RGB code 0,0,255" & chr(13) , "BLUE", b)
Dim visProperties1 As VisProperty
Set visProperties1 = CATIA.ActiveDocument.Selection.VisProperties
Dim r, g, b
'Changes the color of all selected
'imposing inheritance
Obj2.SetRealColor r,g,b,1
'Changes the transparency of all the objects to mid-transparency
' (for opacity=128/255) and imposing inheritance
Obj2.SetRealOpacity 255,1
End Sub
Next CATScript is shorter, without inputs, you have to change the RGB code and adapt to CATPart
Language="VBSCRIPT"
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
Set visPropertySet1 = selection1.VisProperties
visPropertySet1.SetRealColor 210,210,255,1
visProperties1.SetRealOpacity 255,1
selection1.Clear
End Sub
If you want you can also do (but changing RGB code to what you want)
Sub CATMain ()
Dim sel1 As Selection
Set sel1= CATIA.ActiveDocument.Selection
sel1.Clear
sel1.Add CATIA.ActiveDocument.Part.MainBody
sel1.VisProperties.SetRealColor 0, 255, 0, 1
End Sub
And there are few other ways to solve what you want
For resources to see how you can programm in CATIA, check this forum for CATIA_Portable_Script_Center. The best resource is anyway v5Automation.chm file in your CATIA installation folder, there you will find all kind of explanations and examples.
Fernando
https://picasaweb.google.com/102257836106335725208
Nick
APM Consortium Inc.
