running ANSYS 13 mechanical on MATLAB for optimization
I´m running ANSYS 13 mechanical on MATLAB. I´m trying to run optimization on an ANSYS input file. Can you tell me what is the command to run ANSYS 13 mechanical on MATLAB?
I know I should use the dos command, but I don´t know the correct syntax.
regards,
Hugo
regards,
Hugo
RE: running ANSYS 13 mechanical on MATLAB for optimization
Once you know the command you need then the matlab is just
dos('your command line goes here')
Cheers
Greg Locock
