Motion simulation- no contact at zero time
Hello!
I started using motion simulation a few weeks ago, so I am new in this area.
My problem is presented at picture attached. I want to simulate a motion of rod and lever. The lever is pushed by Pin 1 when plate is moving left to right and pushed by Pin 2 when plate is moving right to left.
My question is: what kind of joint should i use to simulate the movement of lever when plate is movin left to right (Pin 1 is pushing the lever), but when in T=0 (zero time) those two elements are not in contact?
RE: Motion simulation- no contact at zero time
The material properties are tricky to set though.
Tomas
