Ansys WorkBench Problem with Symmetry Option
I have a problem with WB. In tree Outline, in "Model", I insert "Symmetry", but the folder is empty! I want to say: "Details of "Symmetry" is empty!! I need change there some things for get AxiSymmetry, like as in APDL: /expand,36,axis,fulL,,10 .
Do you know where is the problem?
Other way: Where should I put a command with /expand,36,axis,fulL,,10 for get the body's virtual simulation???
Thank you!!!
RE: Ansys WorkBench Problem with Symmetry Option
I have seen other problem: I haven't "User Definied Result" in insert options on Solution tree.
Idea?
Thanks.-
Hallo, Pixa,
You can solve your problem if you select Beta Option:
Main Workbench's Window, Tools, Appearance, down scroll: beta options (you have to select it.-)
Good Luck!!
Thank you. I'm going to try it!!!
